Currently, when I go to add a theme in Wordpress, I am only given the option to upload a file. It seems I no longer have a connection to Wordpress.orgs themes from the admin panel.
Has anyone else experienced this? Feature? Bug?
Thanks for reaching out Geoff. In troubleshooting this we discovered that there was a plugin conflict causing the issue. Renaming the WordPress plugins directory to plugins_deactivated caused the theme selector to load correctly.
To determine which plugin is causing the trouble, each plugin will need to be deactivated one at a time. I wrote a Community Help article Troubleshooting Common WordPress Errors which has some tips for the best way to do this.
An alternative solution would be to he temporarily rename the plugins directory as I did above, look for a theme, install as needed, then rename the plugins directory back when this has been done.
Gordon Hawley
Customer Support Specialist
Okay, the plug-ins were deactivated. I deleted plug-ins I wasn’t using or that were redundant. I updated to the latest release of WP today. The media library is now working and I am now able to connect to the theme library. The classic editor is working fine.
BUT NOW: The only site that is working in my multisite is my main blog. The main blog is “Brainstorm in Progress” - the other five kick back a 404 error.
Geoffrey B. Cain
http://www.geoffcain.com
“Without a diversity of opinion, the discovery of truth is impossible.” - A. v. Humboldt
| gordonhawley
December 8 |
Hello Geoff,
Thanks for your patience while this was investigated. We discovered that there is a plugin conflict causing this issue. Renaming the plugins directory to plugins_deactivated caused the theme selector to load correctly.
You will need to deactivate each plugin one at a time to determine which is causing the issue. I have some tips for doing this in my Community Help article Troubleshooting Common WordPress Errors.
The alternative solution would be to he temporarily rename the plugins directory, look for a theme, and install one, then rename the plugins directory back when this has been done.
Let me know if you have any other questions or need further assistance.
Gordon Hawley
Reclaim Hosting
Geoff, we’ve been looking at this issue throughout the day but haven’t been able to narrow down what’s causing the 404 errors with your other sites. We’ll continue working on it tomorrow.
Appreciate your patience while this is being looked into.
Gordon Hawley
Hi Gordon,
I am not sure why it did that either. After reading your replies, I suspected there was some error in the update process. What I decided to do was to take a fresh back up, disable plug-ins, remove sites from the multisite that were plug-in heavy, uninstall plug-ins that were no longer needed and then slowly turn everything back on. Only then did I do the update. It seems to all be working - lighter and faster.
Thanks for your time on this,
Geoff
Geoff, pleased to hear everything is sorted out and running as it should again.
Gordon Hawley
