Advantages of A or CNAME dns records?
Is there an advantage to using A or CNAME dns records for custom domains pointing to cloud servers?
Hey Chris,
Main advantage of CNAME is if IP address changes the mapping is unaffected, whereas if it’s an A record and the IP address changes for the environment the mapping breaks. Other than that no discernible difference.
I believe the best option is to use ANAME record where it’s possible (if your DNS provider supports it). It will give you advantages of the both: unaffected mapping if the IP address changes and you can bind the record to the “naked” domain without www. prefix.
Ruslan,
Do you mean CNAME or A records?
Jim, I mean ANAME, it’s like a mix of CNAME and A record. More details can be found at the link https://tools.ietf.org/id/draft-ietf-dnsop-aname-01.html.
That is new to me, thanks for the link. Will have to play around with that for my Jelastic environments that have mapped domains
Interesting. It appears that hover, which I use for domains, doesn’t offer ANAME records.
You can change your DNS to Cloudflare and use their service https://blog.cloudflare.com/introducing-cname-flattening-rfc-compliant-cnames-at-a-domains-root/
