Does anyone know of a plugin or other easy way to enable a custom “citation” in Omeka? The auto-generated citations are inaccurate whenever content is brought in from outside the Omeka instance (which is most of the time in the Omeka sites I’ve built or seen). It helps to add info to the “Source” field, but then the citation field just adds the Source info to the auto-fill citation, but doesn’t replace it. Thanks in advance for any tips -
Hi there! It looks like there’s a custom plugin written by an Omeka Community member that would fit your needs! I see this thread on the Omeka Forums: Editing citations on omeka - Omeka Classic - Omeka Forum
I would definitely recommend checking them out as well, the forums over there are very active and could help you get set up.
