I’m attempting to install a Laravel-based application on Cloud, which I have previously installed on DoOO without any issue. I cross-referenced the php modules that are up and running on my university’s DoOO environment with those running on Cloud and identified all those not enabled. I went through php.ini and enabled all of those I could find; only a few were unavailable in PHP 7.4 - enchant, readline, sysvmsg, wddx.
The application keeps giving a general Error 500 when doing a specific action; the application log for this error is at the bottom of this post. I do not know if one of the four ‘missing’ modules from above could be the issue. But I do know that this exact same application/version works without issue on DoOO, but has this error in Cloud.
Application’s Error log:
[2020-07-09 14:57:19] production.ERROR: Array and string offset access syntax with curly braces is deprecated {“userId”:1,“exception”:"[object] (ErrorException(code: 0): Array and string offset access syntax with curly braces is deprecated at /var/www/webroot/kora/app/KoraFields/FileTypeField.php:967)
[stacktrace]
#0 /var/www/webroot/kora/vendor/composer/ClassLoader.php(444): Illuminate\Foundation\Bootstrap\HandleExceptions->handleError(8192, ‘Array and strin…’, ‘/var/www/webroo…’, 967, Array)
#1 /var/www/webroot/kora/vendor/composer/ClassLoader.php(444): include()
#2 /var/www/webroot/kora/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile(‘/var/www/webroo…’)
#3 [internal function]: Composer\Autoload\ClassLoader->loadClass(‘App\\KoraFields\\…’)
#4 /var/www/webroot/kora/app/KoraFields/DocumentsField.php(5): spl_autoload_call(‘App\\KoraFields\\…’)
#5 /var/www/webroot/kora/vendor/composer/ClassLoader.php(444): include(‘/var/www/webroo…’)
#6 /var/www/webroot/kora/vendor/composer/ClassLoader.php(322): Composer\Autoload\includeFile(‘/var/www/webroo…’)
#7 [internal function]: Composer\Autoload\ClassLoader->loadClass(‘App\\KoraFields\\…’)
#8 /var/www/webroot/kora/app/Form.php(411): spl_autoload_call(‘App\\KoraFields\\…’)
#9 /var/www/webroot/kora/app/Http/Controllers/FieldController.php(107): App\Form->getFieldModel(‘Documents’)
#10 [internal function]: App\Http\Controllers\FieldController->store(Object(App\Http\Requests\FieldRequest), ‘1’, ‘1’)
#11 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/Controller.php(54): call_user_func_array(Array, Array)
#12 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/ControllerDispatcher.php(45): Illuminate\Routing\Controller->callAction(‘store’, Array)
#13 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/Route.php(219): Illuminate\Routing\ControllerDispatcher->dispatch(Object(Illuminate\Routing\Route), Object(App\Http\Controllers\FieldController), ‘store’)
#14 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/Route.php(176): Illuminate\Routing\Route->runController()
#15 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/Router.php(680): Illuminate\Routing\Route->run()
#16 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(130): Illuminate\Routing\Router->Illuminate\Routing\{closure}(Object(Illuminate\Http\Request))
#17 /var/www/webroot/kora/app/Http/Middleware/IsActive.php(28): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#18 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\IsActive->handle(Object(Illuminate\Http\Request), Object(Closure))
#19 /var/www/webroot/kora/app/Http/Middleware/Authenticate.php(64): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#20 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\Authenticate->handle(Object(Illuminate\Http\Request), Object(Closure))
#21 /var/www/webroot/kora/app/Http/Middleware/SetLanguage.php(61): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#22 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\SetLanguage->handle(Object(Illuminate\Http\Request), Object(Closure))
#23 /var/www/webroot/kora/app/Http/Middleware/VerifyCsrfToken.php(48): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#24 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): App\Http\Middleware\VerifyCsrfToken->handle(Object(Illuminate\Http\Request), Object(Closure))
#25 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/Middleware/SubstituteBindings.php(41): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#26 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Routing\Middleware\SubstituteBindings->handle(Object(Illuminate\Http\Request), Object(Closure))
#27 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/View/Middleware/ShareErrorsFromSession.php(49): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#28 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\View\Middleware\ShareErrorsFromSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#29 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Session/Middleware/StartSession.php(56): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#30 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Session\Middleware\StartSession->handle(Object(Illuminate\Http\Request), Object(Closure))
#31 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/AddQueuedCookiesToResponse.php(37): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#32 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Cookie\Middleware\AddQueuedCookiesToResponse->handle(Object(Illuminate\Http\Request), Object(Closure))
#33 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Cookie/Middleware/EncryptCookies.php(66): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#34 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Cookie\Middleware\EncryptCookies->handle(Object(Illuminate\Http\Request), Object(Closure))
#35 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Foundation/Http/Middleware/CheckForMaintenanceMode.php(62): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#36 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(171): Illuminate\Foundation\Http\Middleware\CheckForMaintenanceMode->handle(Object(Illuminate\Http\Request), Object(Closure))
#37 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#38 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/Router.php(682): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#39 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/Router.php(657): Illuminate\Routing\Router->runRouteWithinStack(Object(Illuminate\Routing\Route), Object(Illuminate\Http\Request))
#40 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/Router.php(623): Illuminate\Routing\Router->runRoute(Object(Illuminate\Http\Request), Object(Illuminate\Routing\Route))
#41 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Routing/Router.php(612): Illuminate\Routing\Router->dispatchToRoute(Object(Illuminate\Http\Request))
#42 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(176): Illuminate\Routing\Router->dispatch(Object(Illuminate\Http\Request))
#43 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(130): Illuminate\Foundation\Http\Kernel->Illuminate\Foundation\Http\{closure}(Object(Illuminate\Http\Request))
#44 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Pipeline/Pipeline.php(105): Illuminate\Pipeline\Pipeline->Illuminate\Pipeline\{closure}(Object(Illuminate\Http\Request))
#45 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(151): Illuminate\Pipeline\Pipeline->then(Object(Closure))
#46 /var/www/webroot/kora/vendor/laravel/framework/src/Illuminate/Foundation/Http/Kernel.php(116): Illuminate\Foundation\Http\Kernel->sendRequestThroughRouter(Object(Illuminate\Http\Request))
#47 /var/www/webroot/kora/public/index.php(52): Illuminate\Foundation\Http\Kernel->handle(Object(Illuminate\Http\Request))
#48 {main}
