I installed the Commons in a Box App here in Reclaim Hosting. I can find it listed under Installatron
But how do I access the C. in a Box App to actually enter some content that I want to show up on my website? How can I access the functions? The opening screen only shows a template picture and my customized title etc.
this is my domain: www.lighthouseclassics.org
Need urgent help here!!! ![]()
Claudia
Use the second link here to access the dashboard:
You’ll login with the username and password you set during installation of the application.
Thank you for the quick reply.
It says this after I use the login as you said:
Sorry, you are not allowed to access this page.
It looks like there was a missing dependency on the server you’re on needed for CBOX to work. I just got that fixed up but you will need to reinstall CBOX for it to work properly. I would try uninstalling and reinstalling it and it should work a lot better for you (and look better as well
Thank you again! I feel so lost still trying to set it all up. My software engineer seems to have let me down six weeks prior to project start! Well, miracles are supposed to happen? I will pray for one now…
And of course try out what you suggested right away ![]()
