HAXcms has now been added to the Marketplace. Headless Authoring eXperience (HAX) is a next generation block editor that works anywhere via web components. HAXcms seeks to be the smallest possible back-end CMS to make HAX work and be able to build websites with it.
You can find HAXcms by clicking Marketplace and navigating to the Education category or searching by name.
Installing is as easy as setting an environment name and region for the install. SSL will be provisioned automatically for the environment and your install will be up and running after several minutes. The installer dialog will provide and administrative URL and login credentials once setup is complete.
Once the install is complete your copy of HAXcms is online and available at the provided URL.
