I have a simple database search site built using Elixir/Phoenix, and I was not able to figure out whether it would be possible to host this application on Reclaim. Has anybody deployed a phoenix application via this service? If so, what is that process like? If not, is there an easy way to make this program compatible with the service?
Thanks in advance for your help!
I’m not terribly familiar with that framework but I don’t see any references to cPanel compatibility which is the stack we use (cPanel is LAMP based and most of the scripting languages are PHP, Python, Perl). I did find this which may help in deciding a good host Low-cost, no-fuss Elixir app hosting? - Chat / Discussions - Elixir Programming Language Forum
Hi there! Adding to this thread, I would check out Reclaim Cloud! This sounds like it would be a good fit for the application you’re looking to run.
