ImageMagick not creating thumbnails from PDFs
Hi all,
Running into an issue that I can’t seem to track down. I am not getting thumbnails generated from the PDFs I’m attaching to items:
A couple notes:
  • The ImageMagick path is set correctly.
  • I’ve set background.php.path to the correct path (used it when I did a CSV import)
  • I am attaching PDFs using the Dropbox plugin – I don’t know if that has an affect.
Thanks ahead of time for any pointers!
Hi Jason!
First, please verify that your ImageMagick path is indeed correct by using the following guide: https://forums.reclaimhosting.com/t/working-with-omeka/194. If you end up changing the path, you would need to reupload-- Omeka does not go back and update previous uploads to create thumbnails.
I would also take the dropbox plugin out of the equation to see if there’s a confliction there.
All of the above said, Omeka Forums may be better suited for this issue. Apologies we can’t be of further help!
Hi @laurenhanks! Thanks for the suggestions. Unfortunately I still seem to be running into the issue. I’ll pop over to the Omeka forums and ask there. Thanks!
I wanted to link to the Omeka thread I started, just to keep this conversation together in case others go looking for the same question.
Regarding that thread: does Reclaim’s version of ImageMagick (or GhostScript, perhaps) include the ability to support JPEG2000?
I’m not sure I know the answer to that. We install the one provided by the CentOS 7 repos (just a basic yum install ImageMagick). Looks like it’s ImageMagick 6.7.8-9
