Greetings, comrades. I’ve installed Scalar 2 into my domain, and all looks good. However, when I try to import my students’ Scalar books (housed in their own domains) to my Scalar install - - via target public url - - the import won’t go through. Oddly, when I import books into my Scalar account at scalar.usc.edu - - import proceeds happily and successfully.
Why the difference? Is there some server-side bolt I need to attach more securely etc.?
Grazie
Larry H.
PS It’s fine if the book copies are stored on the scalar.usc.edu site, but I really wanted to shelve them in my domain to keep them should students not renew/continue their domains (via Reclaim).
That is indeed odd. Can you shoot me some example URLs of books to test with? (If you want to PM with the URLs that’s fine).
Sure - - public scalar books (to be imported into Reclaim hosted scalar install):
http://scalar.paxiplace.com/education/wikipedia-scalar-project/index
Apparently if you try to import an http URL from an https instance of Scalar or vice versa the mismatch causes issues. When I logged into your Scalar install from http and imported the http URL for http://scalar.paxiplace.com/education/wikipedia-scalar-project/index that went through so I would give it a try with the others keeping that in mind.
Very interesting . . .but why do think the scalar.usc.edu site will import from the https vs. my install of scalar?
When you were importing the books were you on the https version of your site or http? I’m kind of just guessing this is the cause since when I switched I was able to import (I started first with https for your instance, I see the http://scalar.usc.edu/ instance is not https so perhaps http can import regardless but https can only import other https URLs). Let me know if there’s an import that still fails.
Makes sense. I was importing via the https version. ('Though I was importing from https versions - - so, in a sense, no mismatch. Perhaps it’s just importing into an https setup?)
In any case, thanks a million for the help! Hope all is well and feliz ano nuevo.
