Hello,
I've recently attempted to use Bridgy with my [WordPress website](http…s://willtmonroe.com) to post to [Twitter](https://twitter.com/willtmonroe). My procedure is pretty simple, I write a short post (see below) and select the option to `Syndicate to Twitter via Bridgy`. A few days ago, this succeeded but since then I've just had a series of errors.
The post can be found here: https://willtmonroe.com/uncategorized/104/
The error I can see on Brid.gy is below.
138.197.169.52 - - [01/Sep/2019:12:43:47 -0700] "POST /publish/webmention HTTP/1.1" 400 477 "https://brid.gy/publish/webmention" "WordPress/5.2.2; https://willtmonroe.com; sending Webmention"
2019-09-01 19:43:16.921900 I Params: [('source', u'https://willtmonroe.com/uncategorized/104/'), ('target', u'https://brid.gy/publish/twitter'), ('bridgy_omit_link', u'maybe')]
2019-09-01 19:43:16.924536 I requests.head https://willtmonroe.com/uncategorized/104/ {'headers': {'User-Agent': u'...'}}
2019-09-01 19:43:31.916378 W Couldn't resolve URL https://willtmonroe.com/uncategorized/104/ : (<requests.packages.urllib3.contrib.appengine.AppEngineManager object at 0x150cdb6bc1d0>, DeadlineExceededError('Deadline exceeded while waiting for HTTP response from URL: https://willtmonroe.com/uncategorized/104/',))
2019-09-01 19:43:31.950439 I Source: https://brid.gy/twitter/willtmonroe , features [u'publish', u'listen'], status enabled, poll status polling
2019-09-01 19:43:32.149888 D Publish entity: 'aglzfmJy...'
2019-09-01 19:43:32.202242 I requests.get https://willtmonroe.com/uncategorized/104/ {'headers': {'User-Agent': u'...'}}
2019-09-01 19:43:47.192272 I Connection failure: (<requests.packages.urllib3.contrib.appengine.AppEngineManager object at 0x150cdb2c3210>, DeadlineExceededError('Deadline exceeded while waiting for HTTP response from URL: https://willtmonroe.com/uncategorized/104/',))
Traceback (most recent call last):
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/publish.py", line 216, in _run
resp = self.fetch_mf2(url, raise_errors=True)
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/webmention.py", line 64, in fetch_mf2
fetched = util.requests_get(url)
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/util.py", line 209, in requests_get
resp = util.requests_get(url, stream=True, **kwargs)
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/local/lib/python2.7/site-packages/oauth_dropins/webutil/util.py", line 1327, in call
return getattr(requests, fn)(url, *args, **kwargs)
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/local/lib/python2.7/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/local/lib/python2.7/site-packages/requests/api.py", line 60, in request
return session.request(method=method, url=url, **kwargs)
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/local/lib/python2.7/site-packages/requests/sessions.py", line 533, in request
resp = self.send(prep, **send_kwargs)
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/local/lib/python2.7/site-packages/requests/sessions.py", line 646, in send
r = adapter.send(request, **kwargs)
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/local/lib/python2.7/site-packages/requests/adapters.py", line 449, in send
timeout=timeout
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/local/lib/python2.7/site-packages/requests_toolbelt/adapters/appengine.py", line 172, in urlopen
**response_kw)
File "/base/data/home/apps/s~brid-gy/8.420691788766043574/local/lib/python2.7/site-packages/urllib3/contrib/appengine.py", line 152, in urlopen
raise TimeoutError(self, e)
TimeoutError: (<requests.packages.urllib3.contrib.appengine.AppEngineManager object at 0x150cdb2c3210>, DeadlineExceededError('Deadline exceeded while waiting for HTTP response from URL: https://willtmonroe.com/uncategorized/104/',))
2019-09-01 19:43:47.201390 I Converting code ... to 504
2019-09-01 19:43:47.201531 I Could not fetch source URL https://willtmonroe.com/uncategorized/104/
timeout=timeout
**response_kw)
Do you have any advice on how I could troubleshoot this?
