I followed these instructions to run Omeka Classic through Reclaim Cloud. As soon as I fill out the superuser form, the site crashes and defaults to this:
Zend_Db_Statement_Mysqli_Exception
Mysqli prepare error: Table ‘omekatest2.omeka_schema_migrations’ doesn’t exist
Zend_Db_Statement_Mysqli_Exception: Mysqli prepare error: Table 'omekatest2.omeka_schema_migrations' doesn't exist in /var/www/webroot/ROOT/application/libraries/Zend/Db/Statement/Mysqli.php:77 Stack trace: #0 /var/www/webroot/ROOT/application/libraries/Zend/Db/Statement.php(115): Zend_Db_Statement_Mysqli->_prepare('SELECT version ...') #1 /var/www/webroot/ROOT/application/libraries/Zend/Db/Adapter/Mysqli.php(388): Zend_Db_Statement->__construct(Object(Zend_Db_Adapter_Mysqli), 'SELECT version ...') #2 /var/www/webroot/ROOT/application/libraries/Zend/Db/Adapter/Abstract.php(479): Zend_Db_Adapter_Mysqli->prepare('SELECT version ...') #3 /var/www/webroot/ROOT/application/libraries/Zend/Db/Adapter/Abstract.php(794): Zend_Db_Adapter_Abstract->query('SELECT version ...', Array) #4 /var/www/webroot/ROOT/application/libraries/Omeka/Db.php(80): Zend_Db_Adapter_Abstract->fetchCol('SELECT version ...') #5 /var/www/webroot/ROOT/application/libraries/Omeka/Db/Migration/Manager.php(178): Omeka_Db->__call('fetchCol', Array) #6 /var/www/webroot/ROOT/application/libraries/Omeka/Db/Migration/Manager.php(268): Omeka_Db_Migration_Manager->_getAllMigratedVersions() #7 /var/www/webroot/ROOT/application/libraries/Omeka/Db/Migration/Manager.php(120): Omeka_Db_Migration_Manager->_getPendingMigrations(Object(DateTime)) #8 /var/www/webroot/ROOT/application/libraries/Omeka/Db/Migration/Manager.php(134): Omeka_Db_Migration_Manager->canUpgrade() #9 /var/www/webroot/ROOT/application/libraries/Omeka/Controller/Plugin/Upgrade.php(55): Omeka_Db_Migration_Manager->dbNeedsUpgrade() #10 /var/www/webroot/ROOT/application/libraries/Omeka/Controller/Plugin/Upgrade.php(39): Omeka_Controller_Plugin_Upgrade->_dbNeedsUpgrade() #11 /var/www/webroot/ROOT/application/libraries/Zend/Controller/Plugin/Broker.php(287): Omeka_Controller_Plugin_Upgrade->dispatchLoopStartup(Object(Zend_Controller_Request_Http)) #12 /var/www/webroot/ROOT/application/libraries/Zend/Controller/Front.php(928): Zend_Controller_Plugin_Broker->dispatchLoopStartup(Object(Zend_Controller_Request_Http)) #13 /var/www/webroot/ROOT/application/libraries/Zend/Application/Bootstrap/Bootstrap.php(105): Zend_Controller_Front->dispatch() #14 /var/www/webroot/ROOT/application/libraries/Zend/Application.php(384): Zend_Application_Bootstrap_Bootstrap->run() #15 /var/www/webroot/ROOT/application/libraries/Omeka/Application.php(73): Zend_Application->run() #16 /var/www/webroot/ROOT/index.php(23): Omeka_Application->run() #17 {main}
I’ve tried creating the table manually via PHPMyAdmin, but that creates a different issue. It seems like the issue might be on Omeka’s side, but I want to confirm before asking there.
