In Omeka S, my Item List title does not match the updated and saved title in the Item Edit. Anyone encounter this issue?
Thank you,
Doug
Thank you,
Doug
What version Omeka S are you using? That may affect how confident I am in suggesting something.
But absent that info, I see you are using MODS for the metadata. Is it possible that a Dublin Core Title was created and Omeka is preferring the DC version? My understanding is that the vocabularies can run in parallel so in principle an Item could have a DC title and a MODS title.
@Douglas_Higgins I can replicate this with my own testing environment (4.0.1), even removing the DC resource template from the mix doesn’t seem to resolve. My guess is that Omeka S isn’t designed to display the title metadata field from any vocabulary not in the box in the item list (this is just a guess though). I’d recommend posting to the official Omeka forum or opening an issue in their GitHub.
