Hello!
I’m trying to install an Omeka S site that will host some PDFS. However, I keep running into erros that involve pdftk – the advice given was to install it via terminal. As far as I can assess, I cannot install it via terminal, and need to ask Reclaim to do that. Is that correct?
Example errors:
Unable to process pdf: Command pdftk unavailable or failed: pdftk A=‘/tmp/omekagQQZfm’ dump_data_utf8
Unable to process pdf: Command pdftk unavailable or failed: /public_html/obscena/modules/BulkImport/vendor/mikehaertl/php-shellcommand A=‘/tmp/omekahF0uLt’ dump_data_utf8
