Solr searching as an option for Omeka or Omeka S
I have a user on campus who is asking “if Solr searching (with a Solr instance hosted by Reclaim) is an option for either Omeka or Omeka-S with Reclaim?” I see that we have Solr installed as a plug-in in WHM, but that seems to be enabled only for searching IMAP mailboxes. Thanks.
Setting up SOLR on our servers is not supported. cPanel uses it for email search but there is not an option to hook into that and it’s beyond the scope of our support to integrate it. We can open the ports necessary but it requires its own server separate from cPanel so we recommend looking into a hosted SOLR solution such as https://www.websolr.com
Thanks Tim. Our library has its own Omeka install, so they will probably just continue to direct projects there.
