Trouble with OpenLayers in Scripto/Omeka Configuration
So I have installed the Scripto plugin for my Omeka Classic install, and when trying to select “OpenLayers” rather than “Omeka default” in the Scripto configuration settings, I get hit with a “Warning: getimagesize(): http:// wrapper is disabled in the server configuration by allow_url_fopen=0 in …/plugins/Scripto/ScriptoPlugin.php on line 410” message on the live site.
The thing is there is not an “allow_url_fopen” on that line or anywhere else in that php file.
Has anyone come in contact with this error/know how to fix it?
Thanks!
Hmmm, allow_url_fopen is a default enabled setting on our servers but it’s quite likely that a server slipped through the cracks and it’s disabled for some reason. What domain are you working with, I’d be happy to check on that.
It’s for my http://www.trexler.newaberdream.bergbuilds.domains omeka install
Gotcha, that setting is a bit more inconsistent on our school setups. Give it a try now and let me know if you continue to experience any issues.
Thank you so much, it works!
