I am trying to embed pages from my WP website into my Moodle assignment description (version 3.5). Our tech support says I need an embed code. Does anyone know of a good plugin for that? I have tried searching but haven’t found one that works yet.
According to Embedding External Websites into Moodle | Tournas Dimitrios you should only need the URL itself rather than any code (though that site is a bit old so not sure if things have changed in Moodle or if there are restrictions in place on what you can and can’t do). Can’t think of any reason that shouldn’t work with WordPress or any other site. I will note you may want to use the https version of your URL since often embedding in the LMS will require that.
Thank you for the advice here. The embedding isn’t working inside Moodle yet. It shows a blank box.
I will try generating my own using the plugin mentioned but I have no clue what I am doing with it. I installed it and activated it … and looked for instructions. The “plug in site” link brings me to your profile woodwardtw (Tom Woodward) · GitHub
I see the embed code on my website, but when I put it inside Moodle I get a blank box. It must be a Moodle issue.
huh . . . not sure about why that would happen. I’ve run it on a couple different sites/setups with no issues. If you end up needing/wanting it let me know and I can take a closer look.
In any case, @cogdog is correct that you’ll be out of luck if you don’t have https for an https embed.
@NurseKillam Your site probably has an SSL cert, but it may not be forced. Have you tried just adding https in the URL instead of http? We have a decent guide I wrote recently about the whole process at https://forums.reclaimhosting.com/t/why-does-my-site-say-not-secure/1764 that may help if you do want to make sure all URLs redirect to https automatically.
