Adapt Authoring Tool now in Marketplace
Difficulty: Beginner
Estimated Cloudlet Usage: 4
Adapt Learning’s Authoring Tool has now been added to the Marketplace. Adapt is a free and easy to use framework and authoring tool that creates fully responsive, multi-device, HTML5 e-learning content. You can learn more about Adapt at https://www.adaptlearning.org/.
You can find the Adapt Authoring Tool by clicking the Marketplace and then Education or searching by name.
Screen Shot 2020-06-04 at 11.29.34 AM
Installing is as easy as setting an environment name and region for the install. SSL will be provisioned automatically for the environment and your install will be up and running in just a few minutes. The installer dialog will provide the URL and login credentials upon completion of setup.
Once the install is complete your copy of the Adapt Authoring Tool is online and available at the provided URL.
A post was split to a new topic: What is the Marketplace?
